Phoenix Models Giles G-202 Electric Sport Model
Old 08-19-2015, 02:13 AM
guapoman2000
Space Ship 1
guapoman2000's Avatar
Default Phoenix Models Giles G-202 Electric Sport Model
Greetings good people,
Just so you all know, there is an earlier Review of this same model published at RCUNIVERSE back in August 2004 by Nathon Maat and you can see it at:
http://www.rcuniverse.com/magazine/a...article_id=334
I have purchased a slightly used Giles G-202 by Phoenix Models and setup by a good friend that goes by dbc over at RCGroups dot com. The model is in better shape then when it got out of the box since his setup skills are just amazing and very meticulous. The plane came in at 4 lb 15 oz without the battery. It required 1 oz of nose weight and a 15.5 oz battery to achieve balance. AUW just under 6 lb and well under spec.
The model is powered by the Emax BL3526/04 is an 8.1 ounce, 860KV, 1000 watt outrunner brushless motor that is equivalent to a .46 nitro engine. It's a good choice for sport and scale airplanes weighing 3 to 7 lbs, and 3D models up to 4.5 lbs. and coupled with a 60a ESC w/switch mode 5a BEC and Hitec HS-311 servos. The motor mounting holes on the board did not line up with the mount on the Emax motor. These Phoenix motor mounting boards are always pre-drilled for Rimfire motors - and they seldom align with other motors. It would have been difficult to redrill the smaller motor mounting board - spacing for the Emax motor X mount was tight. Only two of the holes on the firewall required redrilling and this was the easier and cleaner solution. If you mount the motor directly to the firewall on standoffs, you must carefully observe the amount of offset and adjust accordingly.
The motor's source is:
http://www.headsuphobby.com/Emax-BL3...otor-A-274.htm
Using Turnigy and Admiral 4-Cell, 4400mAH 35C Lithium Polymer batteries it yields 860 Watts (about 144 w/lb ), it's not as overpowered and it's probably a better plane for it. There's plenty of power for aggressive aerobatics, but not for unlimited vertical and 3-D hovering. The plane slows nicely without fear of stalling, and the landing speed even without flaps is reasonable.
Flight Summary Assessment:
I've now got a total of six flights on the Giles. Very pleased with its flight performance. A very nice sport/aerobatic plane that flys smoothly, tracks well, and responds predictably to pilot input. I could not provoke any nasty flight characteristics - did quite a few different stalls and spins with easy recovery from them.
Plane is still plenty stable at the rearmost recommended CG but responds quickly to input. Inverted with just a touch of "up push" required on the elevator but still very responsive here, too. Landing speed is reasonable considering its weight and no flaps. Tracked well on takeoffs. It's hard to find serious fault with the Giles - maybe too heavy for real 3d, but that was never the intention. I don't think anyone would be unhappy with its sport/aerobatic performance.
Flew it using: (Radio Gear and Battery Selection)
1. First Generation Spektrum DX7.
2. DSMX Generation Spektrum AR-400 (4-Channel Receiver).
3. Turnigy 4-Cell, 4400mAH, 35C, Lithium Polymer.
There was just no trim required as this 6-lbs model including battery flew like it was on rails. Best of all, I flew it like I had before as many at the Club didn't believe this was my Maiden flight(s). It looks and performs just amazingly.
Here is the Video: ( make sure "HD" and Full Screen is selected!)
https://vimeo.com/135821979
Some in-flight pictures thanks to my buddy, Gerardo Rivera:
ID:	181498   Click image for larger version
ID:	181499   Click image for larger version
ID:	181500   Click image for larger version
ID:	181501   Click image for larger version
ID:	181503   Click image for larger version
ID:	181504   Click image for larger version
ID:	181505   Click image for larger version
Name:	Carlos and Giles G-202 08-16-2015.jpg
guapoman2000 is offline
Old 08-19-2015, 02:35 AM
Scha-weet ! I know DBC from the EMB 312 Tucano and Super Decathlon threads over there. We call him Florida Dave. I really like the build quality of the two Phoenix models I have. Especially the Tucano. I need to take a close look at this one. Looks great. Nic pics! They are coming out with the Texan II in September.
-Hawk
Old 08-20-2015, 12:51 AM
guapoman2000
Space Ship 1
I played hooky today and went to fly my new large Giles G202 and wow, performed some Knife Edge (need to give it a little more rudder travel) nonetheless it performed great. Spins, and tail slides etc...etc.....
The best today was to bring it up high and cut the power completely. With power OFF, used only rudder to turn so as not to disturb the airflow over the wings and it floated and floated. Not one hint of wing down event and it was super slow!
The power OFF events improved my landings as one landing I allowed slight power and holding slight up elevator and nailed the landing target on the spot. The other landing was completely power OFF and with no wind (Dead Calm) it again hit the target at the start of the runway and rolled nicely and I was able to turn on the hard surface instead of on the grass at the edge of the runway.
Amazing morning and experience!
Old 08-22-2015, 03:02 AM
guapoman2000
Space Ship 1
I did it again today!
Man, I got to stop taking Annual Leave (Vacation) but, I just enjoy this model so much plus with the great weather conditions we had today after ugly thunder storms just the night before, it has been just spectacular and we all need to enjoy it when we can!
Today, flew it with great skill and let me tell you all, it still makes my heart pump UP fast when I command it to do some really hard snaps with a good amount of throttle.
Old 08-22-2015, 06:45 PM
Why don't you tell us how you really feel about the Giles? LOL
Old 08-29-2015, 12:56 AM
guapoman2000
Space Ship 1
Smile
I feel terrible
Last Sunday she hit mother Earth rather hard and it was my fault (RC Pilot Error). Trying to show off on take-off and just flown the "LIGHT" mini-E3D that weighs 21oz., I then, took off with the Giles G-202 and kicked in too much rudder for the model to perform spin action and rubber is just very effective and found myself with the model stall about 20 feet up and I was able to straighten it out, however, all I could do was to watch her pancake in on the grass field.
The good news......on Tuesday a new ARF will arrive and all components will be transferred over to the new one.
I will repair that damaged airframe and take my time as it is repairable.
Anyone like to see damage pic's?
Old 08-29-2015, 04:17 AM
On your's and DBC's rec, I just ordered one. It will be my 3rd Phoenix model. Lost the EMB-312 Tucano this week. My all time favorite. Will reload the 46, esc and servo's from the Tucano into the Giles. ~$100 bucks shipped ? Wow ! Best deal in town.
Interesting history on the full scale. Designed by Richard Giles, he sold them as kits , much like the Vans RV's . In fact he too was from Oregon. Went out of business in 1998. How a Vietnamese model maker like Phoenix would make such a rare discovery for their line-up beats me.
-Hawk
11-14-2021 06:11 PM
11-02-2021 02:03 PM
04-28-2012 03:46 AM
04-08-2012 04:12 AM
x-nitro
03-15-2012 06:06 AM
Quick Reply: Phoenix Models Giles G-202 Electric Sport Model
Page generated in 0.09049 seconds with 21 queries
