PL6 error power status=reduced cell sum error
Old 05-01-2016, 04:01 AM
scoobyrs25
Default PL6 error power status=reduced cell sum error
Like the title says. Every time I try to charge, I eventually get this error:
Power Status = Reduced(Cell sum error)
I'm using the MPA adapter and the charger is set to XH.
scoobyrs25 is offline
Old 05-01-2016, 04:38 AM
scoobyrs25
This seems to only happen during any kind of parallel charge. All good with only one pack.
Old 05-01-2016, 04:51 AM
Are you starting with your packs relatively close in voltage for a para charge? I chose a different para board due to hearing some bad things about the polyfuses on the MPA.
Old 05-01-2016, 04:57 AM
"A "polyfuse" is a fuse made from a polymer. It is a fuse that after it has "blown" will self heal; that is after several days, it will (almost) behave as if nothing has happened."
http://elinux.org/Polyfuses_explained
So I bought an unfused board and only para charge with packs similar in voltage.
Old 05-01-2016, 03:23 PM
I also suggest checking all batteries separately to insure you don't have one with an open balance lead.
Old 05-02-2016, 02:27 AM
i get that same alarm when charging the 4cell packs 4 at a time at a higher charge rest on the pl6. restart the charger and reduce to a slower rate and they are fine. sadly,these are 4000 and 5500mah packs and take forever to charge compared to the small 1000- 1300mah packs which charge 6 at a time and never trigger the alarm/warning of cell count being off.
smitty4980
Batteries & Chargers
28
01-10-2016 06:01 AM
Paul80
14
12-11-2015 10:18 PM
Henry111
118
03-18-2011 07:27 PM
Quick Reply: PL6 error power status=reduced cell sum error
Page generated in 0.06799 seconds with 12 queries
