Batteries and Chargers Forsale/WTB list your batteries and Chargers for sale here
For Sale 6S6P 60A Li-ion NCR18650GA UAV Battery Packs
Old 02-28-2019, 09:38 AM
uavfpvbattery
Alien Member
uavfpvbattery's Avatar
Default 6S6P 60A Li-ion NCR18650GA UAV Battery Packs
CMΞC 6S6P 22.2V 21Ah 60A Lithium-Ion battery pack for professional fixed-wing UAVs/ drones. Made on order.
Technical specs:
Cell count: 36 (same rank cells)
Cell type: Panasonic NCR18650GA Made in Japan
Electrochemistry: Lithium-ion NCA (LiNiCoAlO2)
Series-Parallel-Connected Cells: 6S6P
Battery pack internal resistance (IR): less than 35mΩ
Current capacity: 21Ah (21000 mAh)
Voltage (nominal) 22.2V
Energy capacity: 466Wh
Power: 1332W
Maximum continuous discharge current: 60A
Maximum pulse discharge current (10sec): 80A
Maximum allowable charge voltage: 25.2V
The discharge end voltage should be more than 16.2V (18.6V for long lifespan)
Charging current (CC): max. 10A
Weight: +/- 1800g (including wiring harnesses, connectors & covering)
Physical dimensions (distance between cell pack edges, excluding harnesses): 190 x 70 x 72 mm.
Discharge wire type: Multi-strand 12AWG flexible silicone insulated copper
Gold plated discharge connector: standard XT-90s (custom: EC5, Supra-X ProD5/ProD6, other)
Discharge wire length (pack to connector end) +/- 100mm
Balance Plug: JST-XH 7-pin
Balance wire length (pack to connector end): +/- 70mm
More info: https://uavfpvbattery.com/6s-21000ma...sional-drones/
uavfpvbattery is offline
06-28-2017 04:22 PM
01-09-2017 02:23 AM
Howard Matos
FMA Direct
07-28-2011 02:04 PM
cbatters
Batteries & Chargers
11
05-30-2011 04:51 AM
Quick Reply: For Sale 6S6P 60A Li-ion NCR18650GA UAV Battery Packs
Page generated in 0.05970 seconds with 11 queries
