New Product Announcements Vendors post their latest and greatest products here to let the world know about them
Mini Tumbleweed 3D ARF from Aero Technologies
Old 06-27-2006, 06:27 PM
nexgenarf
Default Mini Tumbleweed 3D ARF from Aero Technologies
Flying 3D aerobatics with an electric powered plane used to be only in the realm of those profile foamie style airplanes. Not any more. Fly 3D with a real 3D airplane, the Mini Tumbleweed ARF from Aero Technologies. Not just a pretty face, the Mini Tumbleweed ARF packs real punch when it comes to aerobatic flying. Things like large wing area, massive control surfaces including functional flaps, and a specially bolt lightweight airframe combine to make the Mini Tumbleweed ARF stand out from its two dimensional brethren.
Each Mini Tumbleweed ARF is built from balsa and plywood hand selected for its lightweight and strength. All parts are CNC cut for accuracy, then jig assembled for a straight and true alignment throughout. After assembly, each component is hand covered with genuine Ultracote® in a highly visible, two color trim scheme that shows off the craftsmanship of the construction. And since this is a NexGen ARF™ model, the parts count is low so assembly time is kept to a minimum. Unlike other ARF models on the market, you'll find the vertical fin and horizontal stabilizer pre-attached to the fuselage, eliminating those time consuming alignment procedures. All control surfaces, rudder, elevators, ailerons and flaps, are pre-hinged and glued securely into place. Rudder and elevator pushrods are preinstalled too. Just hook up your favorite micro radio equipment, install a brushless electric motor and speed control, attach the pre-assembled landing gear (with wheels and fiberglass wheel pants installed) and fiberglass cowl, bolt on the wing and go fly. It's just that simple. It's the NexGen way.
http://www.atecmodels.com
Name:	Mini Tumbleweed 125.jpg
ID:	13373   Click image for larger version
Name:	Mini Tumbleweed Exploded 125.jpg
nexgenarf is offline
Murocflyer
3D Flying
06-04-2008 04:54 AM
jobu
04-01-2008 05:27 AM
pvtzemerak
ParkFlyers
03-05-2008 01:13 PM
luv2fly2
02-06-2008 11:41 PM
nexgenarf
08-03-2006 10:38 PM
Quick Reply: Mini Tumbleweed 3D ARF from Aero Technologies
Page generated in 0.06215 seconds with 15 queries
