E-flite Power 52 Lipo cell range
Old 03-27-2019, 05:03 PM
kargo
Default E-flite Power 52 Lipo cell range
Hi Gang,
Do any of you have experience using a 3S Lipo on an Eflite Power 52 motor? The battery range is listed at 4S to 6S... What are the pro/cons here? Am I just better off using 4S batteries in the larger motors? I haven't really used anything that puts out much more than 500Watts before, so this is new territory for me.
Thanks,
Kargo
kargo is offline
Old 03-28-2019, 03:42 AM
Past President of PSSF
If you operate it on too low a voltage, you will not get the power (watts) out of it without the current going up to the point you will burn out the motor.
I have a E-flite power 52 and I intend to run it on a 6s system to keep the current low, and to be able to run a smaller prop than a lower voltage would require.
Wildflyer is offline
Old 03-28-2019, 05:25 AM
kargo
I wouldn't need the full rated Watts, but I can see what you mean. If I kept within the amp limits of the motor, would it be ok. For example, 55 amps x 3S = 643 Watts, enough for my application...
Thanks for the reply. Kargo
kargo is offline
11-14-2021 06:11 PM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
ServoCity
Batteries & Chargers
08-20-2014 03:33 PM
08-11-2014 04:36 AM
Quick Reply: E-flite Power 52 Lipo cell range
Page generated in 0.07976 seconds with 12 queries
