New micro Fokker D-7 by Tower RTF $79
Old 07-19-2019, 05:41 PM
Griff Murphey
Default New micro Fokker D-7 by Tower RTF $79
This is a gorgeous model far and away nicer than their old WW-1 line. The plane comes in the markings of Ernst Udet complete with Du doch Nicht! Tailplane markings you aint Gonna get me! Great lozenge fabric representation on the lower half of both wings and the upper surface of the lower wing, a nicely painted pilot, music wire landing gear... looks like a well built plastic model. The prop even has a laminated wood effect and makers tradematk. Streamers are attached to the tailplane.
One feature I am not sure about is the motor. The old line motors were highly fragile and any face plant would often result in a totally jammed engine which in turn would often burn out one or the channels in the receiver brick. At this time a photo of the engine is listed as coming on the replacement parts chart, so I cannot say. The plane is solidly glued together rather than taped... I can well admire the great appearance but on a flying model the ease of repair with a taped model is much appreciated. I had thought that since Horizon now owns them maybe they would have gone to tape but no....
Another feature is a super tiny battery, retained by a magnet. I suggest that if you buy one of these planes, you may want to go ahead and order a spare or two.
It comes with a transmitter, which has wire shafts on the gimbal toggles, I can attest that the all plastic ones on their old units were quite fragile.
Have not flown this plane yet!
Griff Murphey is offline
Old 07-20-2019, 12:26 AM
Cute little plane
Old 07-23-2019, 03:26 PM
Griff Murphey
looked good needed a little down elevator trim, I think. I still have not flown mine, its been too windy. This morning it was still but I have patients!
Couple of small notes, the lozenge fabric seems to be a rubbery sheet that has been laminated on, by vacuum or pressure. It should strengthen the wings. Because the wings are undercsmber as anyone who has tried to cover an undercamber stick and tissue knows, special care is needed. My D-7 has perfect coverage on the underside of the lower wing but there are a lot of bubbles in the covering onthe underside of the upper wing. Might be worth checking if a dealer had several in stock. Also I tried checking to see if the new transmitter would talk to the old series of Tower WW-1s and the answer is no. I have not weighed mine but it seems extraordinarily light.
Old 08-11-2019, 02:52 PM
Griff Murphey
I have flown theD-7 about 7 times. Its pretty tender in the air... gets moved around a lot in comparison to my Horizon micro Stearman. I have not weighed it but its super light compared with that Stearman. It has that curved dihedral stick and tissue guys are familiar with which is likely an Issue with the lamination of the Mylar like covering on the wings. Im no expert and am likely not as good a pilot as that 9-10 year old kid in the video Chelle forwarded but I have never had a stick and tissue with this curved dihedral that flew well. This plane likes to swoop up with the slightest increase in throttle.
Still, its good looking and fun if a slight challenge to fly- should be great indoors!
Old 02-12-2020, 03:32 PM
Griff Murphey
I now have 25 flights on this plane. I did damage it trying my first effort at indoor flying and may have loosened the motor mount. Its now flying with a lot more noise, still very sensitive as far as power settings and it will start porpoising without much trouble. Does Best on about 45 pct power. I did bob the prop by about 4mm off each tip and that had helped tame it a bit. Although as a model its a scale beauty I wish Tower would do a taped together fuselage to facilitate maintenance like e-flite does with planes such as the micro Stearman.
Old 02-29-2020, 12:05 PM
Leadchucker
Curmudgeon
Leadchucker's Avatar
Little Fokker and mother Fokker. Mother is electric too
ID:	187882   Click image for larger version
Leadchucker is offline
Old 02-29-2020, 01:45 PM
Griff Murphey
Couple of nice Fokkers. I have been wanting to do Ernst Udets civil one he flew in Germany before WW-2. Id like to know if it was silver or light gray, hard to tell from B&W photos.
Old 04-06-2020, 12:36 AM
Griff Murphey
Default Killed it
Coronavirus boredom got to me and flew it in the front yard. Did a face plant with it on the driveway curb and just like the other previous cheap tower WW-1s it killed the engine, its still pretty and unmarked but Id have to butcher it to get into the nose and transplant a decent motor such as a Horizon E Flite one used in the Stearman. Pretty model, cheap motor. May just let my grandson hang it in his room. I had a grand total of 35 flights with it. It was already running very noisily and eating up the battery, with increasingly shorter flight times.
phillipmorris
02-11-2015 10:00 AM
Tepid Pilot
Warbird Electrics
06-27-2013 02:54 AM
phillipmorris
15
12-23-2012 07:31 AM
Nieuport Fly Guy
09-23-2011 01:30 PM
gklein
13
05-17-2011 04:55 PM
Quick Reply: New micro Fokker D-7 by Tower RTF $79
Page generated in 0.08119 seconds with 13 queries
