ESC Choosing
Old 08-27-2019, 07:05 AM
Tahmid
Default ESC Choosing
Is 20A ESC enough for 3.7-6V Brushed 360 Motor?
Tahmid is offline
Old 08-27-2019, 06:36 PM
Past President of PSSF
Should be
Wildflyer is offline
Old 08-27-2019, 07:50 PM
Just make sure its a Brushed ESC ... and not a Brushless ESC - brushless will not work.
The specs should guide you ... look at the max WATTS of the motor you are using and then divide that by the volts you are going to supply ... that gives the max AMP draw you would expect. Take that as your 75% marker for the ESC you should use ...
ie if the motor is 60W .... then 60W divided by (average of 3.7 - 6) 4.9V = 12.24A
A 15 - 20A Brushed ESC is more than enough.
11-14-2021 06:11 PM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
cver019
07-04-2015 06:04 AM
scoote621
05-06-2011 06:24 PM
Quick Reply: ESC Choosing
Page generated in 0.08836 seconds with 12 queries
