Cheetah U3520-6 motor
Old 10-03-2019, 10:03 PM
Gordone
Default Cheetah U3520-6 motor
I'm trying to find the power specs for this motor, i.e., number of battery cells and amps or watts. I know the kV is 840. It was originally sold by BP Hobbies who stated that Cheetah motors are made by Suppo. The motor is not listed on the Suppo website.
Thanks,
Gordone
Gordone is offline
Old 10-04-2019, 01:18 AM
crxmanpat's Avatar
Looks like Altitude Hobbies still sells the Suppo motor. Here are the specs:
Suppo 3520/6 (42-47) 840kv Specifications:
● Number of Cells: 3-7s lipo; 8-20 cell NiMh
● Max Efficiency Current: 18-40A (>75%)
● No Load Current (10v): 2.1A
● Max Current: 50A/60s
● Max Efficiency: 82%
● Resistance: .050 ohms
● Shaft Size: 5.0mm
● Poles: 14
● Max Watts: 1295W
● Weight: 200g
● Motor Dimensions: 42x47 (mm)
● Motor bolt pattern (back of motor): 22mm x 22mm (hole to hole)
● X-mount hole pattern: 54mm x 54mm (hole to hole)
● Minimum recommended ESC: 50A*
● Recommended Model Weight: 1800-3000g (64-107 oz.)
crxmanpat is offline
Old 10-04-2019, 05:13 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Originally Posted by Gordone View Post
I'm trying to find the power specs for this motor, i.e., number of battery cells ...
Any voltage, as long as current and rpm don't get too high. Wire insulationlacquer can handle several hunderd volt.
ron_van_sommeren is offline
Old 10-04-2019, 10:57 AM
Gordone
Wow, thanks for the quick and thorough response!
Gordone is offline
11-14-2021 06:11 PM
admin
11-14-2021 07:12 AM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
02-16-2016 01:19 AM
Quick Reply: Cheetah U3520-6 motor
Page generated in 0.08913 seconds with 11 queries
