Building a foamy around a wing
Old 07-03-2020, 07:10 PM
AirmanAirhead
Did that tree move??
AirmanAirhead's Avatar
Default Building a foamy around a wing
I have an existing airfoil foam wing, 33" wide by 6" I had it mounted on a foam fuselage that measure 25" a Cub high wing. The fuselage is beat up, and I want to build a new one. I can use the exact same dimensions or make some changes. The original fuse I made was out of heavy pink foam. The new one will be made from sheets of depron I still have.
Any suggestions on staying with the same fuse size or making changes? With the airfoil shaped wing it tended to want to be tail heavy. I assume that was a CG issue but not sure. My goal is to make an easy flyer more on the trainer level to help others learn to fly. Or to just mess around with myself. Any ideas?
AirmanAirhead is offline
Old 07-03-2020, 07:44 PM
I would suggest looking through free plan sites and seeing what has similar to your wing ...
Old 07-04-2020, 05:25 AM
AirmanAirhead
Thanks Nigel, good and simple idea. You prodded me just enough to go on a search. Found a simple balsa wood plan with solid plywood sides, top and bottom, I'm going to build it out of depron and see what happens. Wing size is almost perfect. Should be pretty light. It will be interesting to see where the CG ends up in relation to the plan which calls for a glow engine, etc.
Jeff
Old 07-04-2020, 04:33 PM
Abuelo
Abuelo's Avatar
Might take a look at the Dick's Dream, a 34" foam wing plane from Ace RC. Outerzone has the plan, oz5747.
Originally for the Ace pulse rudder system and a PeeWee .020, flew fine and was the smaller of the Whizard series.
Abuelo is offline
Old 07-04-2020, 05:59 PM
Jeff
What you can do is use wood strips to create a skeleton and then sheet with Depron ... that produces a strong rigid structure without weight.
I'm building a 93" span Lancaster with 6mm pine longerons, ply bulkheads and sheeted with 6mm Depron. Saving about 25% weight against the original ...
Flite-Metal
Electric Ducted Fan Jets
544
10-12-2018 02:18 PM
06-28-2017 05:22 PM
payne9999
98
12-28-2014 06:44 PM
Rcpilet
Foamies
08-26-2013 04:00 AM
Pilotwings24
ParkFlyers
07-28-2013 09:02 PM
Quick Reply: Building a foamy around a wing
Page generated in 0.10439 seconds with 8 queries
