Dihedral Query
Old 08-24-2020, 04:53 PM
liposucker
Default Dihedral Query
Hi all
Hope I'm in the right section for this query.
I am currently converting a free flight I.C. plane to a 4 channel electric. The model is a 1200mm span Bristol Monoplane. There are many little issues to overcome( all part of the fun) but my main concern is the dihedral. The plan shows 35mm dihedral under each wing. No doubt ideal for freeflight but as the conversion will have ailerons, I am thinking I could remove the dihedral completely and have a flat wing.
Any thoughts suggestions on this would be greatly appreciated
liposucker is offline
Old 08-24-2020, 06:29 PM
pmullen503
You could match the dihedral of the real plane. Can you find a scale drawing?
pmullen503 is offline
Old 08-24-2020, 06:38 PM
That would be my first thought as well.
OK ... lets dispel a bit about dihedral and ailerons. Adding ailerons and then removing dihedral totally is not a good idea unless you are into full aerobatics. Leaving some dihedral in even though you have ailerons is a benefit to stability in fact ... it also aids your turns etc.
I know plenty people who have converted old time models and generally they have removed 1/2 to 3/4 of the original dihedral when adding ailerons .....
The old saying - if it looks right - it probably is right ..... applies here.
Old 08-25-2020, 02:07 AM
The Bristol M1C was definitely rigged with some dihedral. About 2 degrees per side.
quorneng is offline
Old 08-25-2020, 04:41 PM
liposucker
Many thanks to all who replied. I'll take all advice on board.
Abuelo
Aerodynamics
08-03-2019 01:06 PM
250rman
ParkFlyers
21
04-18-2013 07:13 PM
250rman
04-04-2013 12:10 PM
paulatgis
26
12-19-2012 01:25 AM
earthsciteach
33
05-16-2011 02:50 PM
Quick Reply: Dihedral Query
Page generated in 0.06430 seconds with 9 queries
