Wing Joiner question
Old 09-07-2020, 02:27 PM
Resolution
Default Wing Joiner question
Picked up a Great Planes Super Stearman kit that was partially built. In the kit as designed it had three pieces of 1/8 plywood glued together to make a 3/8's joiner. The kit was missing the ones for the top wing which are straight so it makes it easy to reproduce. Question is would the three 1/8 pieces glued as called for be stronger or would one 7 ply 3/8 piece work just as well? I have material to go either way just wanted to get some other opinions.
Thanks!
Resolution is offline
Old 09-07-2020, 03:31 PM
Provided the grain goes the right way 3 x 1/8" 3 ply will be stiffer than one 3/8" 7 ply.
3 x 1/8 should have 6 laminations with the grain across the joint. 7 ply will only have 4.
Of course this does assume your glue is as good as that used by the ply manufacturer!
quorneng is offline
Old 09-07-2020, 06:22 PM
Adding to Q's reply ... if you use PU or Epoxy glue and make sure all 3 pcs are pressed together while setting - it should be stiffer and possibly stronger than the single 3/8 piece.
F22trainer
Scale E-Powered Aircraft
13
06-28-2019 08:17 PM
Flite-Metal
Electric Ducted Fan Jets
544
10-12-2018 02:18 PM
06-28-2017 05:22 PM
Off Topic Chit Chat
23
09-23-2014 08:48 PM
WayneG
05-29-2011 09:37 PM
Quick Reply: Wing Joiner question
Page generated in 0.05434 seconds with 8 queries
