Receiver switch on large electrics?
Old 10-08-2020, 02:39 PM
StevenShelby
Default Receiver switch on large electrics?
What is a mattress topper- FAQ - All you need to know
Q: What is a mattress topper?
A: A mattress topper is an extra pad, laid over a mattress to increase the mattress’s support and comfort. Besides, a topper is also a mattress protector, which helps increase the mattress’s durability. Some people think it is just a thin layer placed on a mattress, but today, there are many types of toppers with many special features to suit different demands of users.
Check This Out: Best Mattress Topper Reviews Thekinglive
Q: I want to buy a mattress topper for myself, but I don’t know how to choose a one to suit my requirements. Can you help me?
A: Nowadays, a mattress topper is not only an extra layer, but there are many types on the market. Pillow top mattress toppers have many fibers (cotton, synthetic fibers or both). This type will keep you in a comfortable sleep position and it is suitable for people who turn over frequently as they sleep, especially children.
Memory foam mattress toppers is the second type, mostly made from polyurethane, also known as “memory foam”. The most prominent characteristic of this type of topper is the “weightlessness” sensation, or in other words, it can support and control spinal alignment when you lie on it. It helps side sleepers avoid pains in the back when waking up.
The third type is latex mattress toppers. Most of them are made of latex which is derived from rubber tree sap. Two types of latex that are most popular on the market are Dunlop and Talalay. Dunlop latex is denser and heavier, so it is used for support layers. Talalay latex is much lighter and can be used as a comfort layer.
Before buying a mattress topper, you should take note of some of the characteristics mentioned below:
First thing to consider is the thickness of mattress topper. This property is important when you want to buy foam or latex mattress toppers. Remember that the thicker topper is also the more comfortable one.
Useful Reference: Top Rated Mattress Toppers
The hardness of the topper is also an important property. For latex mattress toppers, density is the factor that affects the hardness of topper. Normally, Dunlop latex is harder and heavier than Talalay latex.
The size of the topper is a point you should consider. On the market, there are four sizes – twin, full, queen and king. You should choose the size to suit your bed or your mattress.
The last thing to consider is the cost.
Q: How to buy a mattress topper on the market?
A: There are many ways to buy a mattress topper, you can search for it on the internet and go directly to the manufacturer’s website or find it on various e-commerce sites such as eBay and Amazon. Or, you can go to the bedding store where you can try out and check directly what the mattress topper you want to buy.
Further Reading: Best Mattress Topper Reviews
Q: What mattress topper is best-suited for side sleepers?
A: For side sleepers, you should choose toppers that can give you adequate support in your preferred sleep position to give you a “weightlessness” sensation. It should be able to support and control your spinal alignment when you lie on it, and help you avoid pains in the back when waking up. You should buy foam mattress toppers, which are made of polyurethane.
The ViscoSoft three-Inch memory foam mattress topper, queen size maybe the best mattress topper for side sleepers. With the gel-infused memory foam technique, it can reduce trapped body heat, while the three inches thick layer helps you avoid sinking into the foam and it relieves your pressure points.
StevenShelby is offline
Old 10-08-2020, 05:56 PM
Basically unless you have a model with permanent installed battery - there is no need for Rx switch.
If you did install a Rx switch - then a normal RC Rx switch is more than enough as its only cutting the 5 - 6V low power Rx supply and has nothing to do with the high power motor supply. But I suggest its not a good idea to have power to ESC / motor and Rx cut out ...
Better idea is to use the Throttle Cut switch on your Tx.
Old 10-08-2020, 07:37 PM
Past President of PSSF
Since you shouldn't leave a Lipo plugged into an ESC for long term waiting or storage, always unplug it.
I have seen a rare ESC with a switch on the receiver lead, but very uncommon today.
Some ESCs used to have an arming button. They didn't do much until you pushed the button, telling them you are ready to go.
I have made a total safe switch by using a series battery connector with one of the battery connectors glued into the side of my seaplane. I made a shorted out battery plug that goes into that when I am ready to fly. It takes a few minutes to get inside the seaplane, so I wanted something that other people could figure out.
The battery plugs into the lead hanging from the inside of the plane, the ESC is plugged into the other lead.
You can buy them also,
here is just one listing, although it has Deans connectors, I had problems with them so now I only use XT60s.
http://www.sharprc.com/armsafe-kit-w...e-max-80-amps/
Wildflyer is offline
Old 10-08-2020, 08:39 PM
The only OEM switch I saw on an electric model was the arming button for a Brushed motor setup. I believe that was based on being able to leave the NiCd / NiMh power pack in the model and still charge it ... BUT the arming ONLY connected the motor ... the RX was still powered all time pack was connected.
Old 11-01-2020, 05:42 PM
What would be the value of a receiver switch? Will you have a separate receiver battery from the main motor battery? That can be done but is rare these days. Normally you run the motor and the receiver from the same battery. The receiver gets its power from the ESC or from a separate device that steps the voltage down.
Normally, with electrics, you put the battery in when you are ready to fly and you disconnect it when you are done so you can charge. So, what does the switch do?
BTW, if you switch off the receiver while you still have the motor battery in, that means that there is nothing controlling the motor while it is still powered. I would not recommend that.
AEAJR is offline
Old 06-09-2021, 09:00 PM
E-Challenged
E-Challenged's Avatar
There are shorting plugs for sale that break the positive lead that goes from battery pack to speed control, when removed from side of model. There are also setups that reduce sparking when connecting battery pack to speed control. These things are used on high cell count models.
E-Challenged is offline
Old 06-10-2021, 08:40 AM
No switch needed at all. Plug the battery in to go. Unplug the battery to Whoa. It is possible you could accidentally leave your battery plugged in doing it any other way.
Old 06-10-2021, 12:36 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Originally Posted by Panther View Post
No switch needed at all. ...
Agreed, a switch would only be an extra point of failure.
ron_van_sommeren is offline
11-14-2021 05:11 PM
11-02-2021 01:03 PM
10
10-29-2015 10:07 PM
wriggs
03-06-2012 09:19 PM
bobskinner
05-10-2011 03:43 AM
Quick Reply: Receiver switch on large electrics?
Page generated in 0.08823 seconds with 9 queries
