1:5.5 Grumman A6A, A6E, A6F, EA6A & KA6D
Old 11-18-2020, 02:29 PM
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Default 1:5.5 Grumman A6A, A6E, A6F, EA6A & KA6D
From ashes...
To once again, "Flight Of The Intruder"
3 piece fuse: Pickup-van-or suv transport. 64" long center section. 119.6" length x 120" w/s assembled. Twin JetFan 110 12s = 42# static thrust.
ID:	188285   Click image for larger version
ID:	188286   Click image for larger version
ID:	188287   Click image for larger version
Flite-Metal is offline
Old 12-06-2020, 08:54 PM
Flite-Metal
Default JetFan 110
Is anyone in WattFlyer interested in large scale EDF jets? I am surprised there have been "0" posts. Is there only interest in foam jets?
Name:	2021-02-18_201258_Jetfans_FSA Outlets.jpg
Old 02-20-2021, 05:30 PM
Flite-Metal
Name:	JF-110 PRO chart new motors 5_ 2016 (2018_01_07 05_54_22 UTC).jpg
Old 06-25-2021, 08:19 PM
Flite-Metal
Using the Edge "F" 160 HV esc on each of our JetFan 110mm 700-98-840 on 12S with a goal of 11 minute flight time...what would be the optimum battery @ ? C rate? I am considering use of 10,000 mah~12,000 mah.
At this level there have been conflicting claims to the best this or that, as best. I am frustrated in not finding real world data for this level of product. At the root of this is of course the A6's...but I will be powering two B-47E's with the same setup.
I will compete with both. 11 minutes is the ultimate goal in that during scale contests there are multiple contestants in the air at the same time. Each took off and land in sequence performing a flight routine typically consuming 6 to 8 minutes.
The reason for the 11 minute goal is if a competitor attempting to land "ahead" of me were to end up doing a pin point landing in the middle of the runway. Yes, judicious throttle management is built into my flight routine working down from altitude performing maneuvers making best use of gravity.
In spite of well planned flight routines, things happen outside everyone's best choice of maneuvers against a maximum of 15 minutes with respect to the rules. In reality all maneuvers are typically performed under eight minutes takeoff to landing roll out.
Any and all recommendations are welcomed...YouTube witnessing preferred... ;^)
Old 06-25-2021, 09:41 PM
crxmanpat's Avatar
Ed,
Going to be tough finding anything that will give you 11 minutes of flight time on EDF. Even flight times of 6 minutes are the holy grail right now. About the only way to get there will be to fly truly scale speeds as EDFs are amp hogs. Unfortunately I don't have any recommendations for you. Good luck in your search!
crxmanpat is offline
Old 06-25-2021, 10:06 PM
Flite-Metal
Default Managing Time = Managing Throttle
Originally Posted by crxmanpat View Post
Ed, Going to be tough finding anything that will give you 11 minutes of flight time on EDF. Even flight times of 6 minutes are the holy grail right now. About the only way to get there will be to fly truly scale speeds as EDFs are amp hogs. Unfortunately I don't have any recommendations for you. Good luck in your search!
The anticipated average throttle during the flight round will be 50~60% considering my weight to thrust ratio of 34# of A6 to 38.9# of thrust. At 10 amp to 12 amp capacity that equates from a pure math stand point.
Old 08-31-2021, 10:51 AM
Flite-Metal
Pat
Last weekend the new SMC 9700's provided 7 minutes with 55% remaining. This after only two discharges in a Yellow F-18.
Old 09-13-2021, 05:20 PM
Flite-Metal
A6 spoilerons:
I shot video of the 32 year old "Flight Of The Intruder" A6 spoilerons...working just as it was just installed yesterday. Futaba should be proud ;^) Its interesting to note the spoileron was held in place with a strip of adhesive tape...yes, adhesive tape.
Note in the pic below, in the lower right, you see the turned up edge of the tape. My 6's spoileron is held in place with acrylic adhesive backed Tyvek spanning the front of the flap bay and bottom side of spoileron. Tyvek is thin but superior in strength to cellophane tape The movie 6 was not designed to last longer than filming the short sequences of the movie.
Click pic 2C
Old 10-05-2021, 08:43 PM
Flite-Metal
Default #1 Of Two Cockpit Versions
ID:	188539   Click image for larger version
Old 06-22-2022, 12:53 AM
Flite-Metal
Default Catching Up
This is a short photo catch-up on where we are with the A6 Intruders.
Old 07-09-2022, 12:53 AM
Flite-Metal
Default Flying Stab Cradle
Currently consummed creating the flying stab cradle. Will post pix as the prototype assembly is more than its current twelve parts. The cradle has a pair of 45kg servos, one per stab with individual pivot shafts and a push-pull rudder servo.
ID:	188791   Click image for larger version
ID:	188792   Click image for larger version
Old 08-07-2022, 09:31 PM
Flite-Metal
Default Stab & Nose Gear Cradles
A lay-up of two weights of Airex infused foam in the last 22 inches of the mold provided an exceptionally light weight but super strong gauge for width and depth of the flying stab cradle. As always, the concern was for balance without excessive all-up-weight on this exceptionally long fuselage. The bottom access hatch is immediately below center of stab rotation. This affords easy access for adjustment of stab and rudder positioning without removing servo cradle.
The vertical centerline of the fuselage is stradled with a pair of stainless steel business form rulers to measure width required for the cradle. Mounting rails above and below the cradle's servo plates provide fixture to the fuselage sides. Measurements shown are 50% of the available widths in the taper. Flying stab center of rotation is 16 3/4 inches from rear end of fuselage.
ID:	188803   Click image for larger version
ID:	188804   Click image for larger version
ID:	188805   Click image for larger version
ID:	188806   Click image for larger version
ID:	188808   Click image for larger version
Bobdaeronort
Pusher Park Jets
03-13-2015 03:28 AM
Quick Reply: 1:5.5 Grumman A6A, A6E, A6F, EA6A & KA6D
Page generated in 0.10926 seconds with 29 queries
