Esc plug地play
Old 03-13-2021, 01:30 AM
jangodog
jangodog's Avatar
Default Esc plug地play
Hi i want a more powerful esc in my Eflite Viper and wanna know if i can install one like this :
https://www.motionrc.eu/products/fre...-v2-049d002002 ?
Is it just Plug地play or do i need some kind of programmer card after i壇 put it in the plane?
jangodog is offline
Old 03-13-2021, 02:32 PM
jangodog
Most ESC in most applications work fine on the default factory setting. All mine have even on 35 mm to 70 mm EDFs.
Has your old ESC failed?
Fitting a bigger capacity ESC does not deliver any more power to an existing set up unless you are also fitting a battery with more cells.
Then you have to worry about the whether the motor can stand the extra amps.
quorneng is offline
Old 03-13-2021, 03:44 PM
jangodog
jangodog's Avatar
Okay. What if i then just switch the motor to a 2950kV instead an leave the 70amp in the Viper? Heard that the 3300 lipos would work with the motor upgrade. The esc works fine.
jangodog is offline
Old 03-13-2021, 05:38 PM
Past President of PSSF
Changing the motor to a different more powerful one may very well push the current beyond what your ESC can handle.
Some EDF's are real power hungry,I have a 70mm that requires a minimum of a 90amp ESC
Need to study what thee new motor requires and then see if your ESC can handle it.
Also if you change the ESC, you my need to adjust the programming in the new one, My motor requires timing set to high.
Wildflyer is offline
Old 03-13-2021, 08:16 PM
jangodog
jangodog's Avatar
I don’t know much about these things but i could start with the bigger motor. Don’t want to spend money on unnecessary electronics. I really like the Viper though only hate that i can’t keep it at home
without taking off the wing because of lack of space. Looking for a way for easier assembly/disasembly
method Thank’s for your input.
jangodog is offline
Old 03-13-2021, 11:17 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
The velocity konstant Kv (in rpm/volt), gives no indication for motorsize, nor for max. motor power (in watt), nor for max.current (in amp鑽e).
Both the motor in your toothbrush and the motor in a 1:1 train motor can have the same Kv.
ron_van_sommeren is offline
Old 03-14-2021, 12:49 AM
jangodog
If you love your Viper then do it and your pocket a favour by leaving it alone!
If you are after more power then trial and error is not the way to go with an EDF.
Only do a change if there is a recommendation from someone who has proved it works by flying with it in a Viper and then follow the recommended changes to the letter.
All electric flying is a compromise. The manufacturer will have selected components that work adequately and reliably. Change something and others may suffer.
quorneng is offline
Old 03-14-2021, 10:21 AM
jangodog
jangodog's Avatar
I hear you. I値l leave the motor setup at stock and just getting either a new fuselage or a hole new Viper.
Thank痴.
jangodog is offline
Old 03-14-2021, 08:27 PM
ron_van_sommeren
Current and power drawn are proportional to Kv cubed. Even a seemingly small change in Kv can give quite an unexpected increase, see examples below.
Whether the motor can handle that increase is a different story, depends on motor max.current and max.power rating.
Expensive example.
A 25% increase in velocity konstant kvウ would (1.25)ウ=2 fold current and power drawn, 100% extra.
Extreme example.
Doubling velocity konstant kvウ would 2ウ=8 fold current and power drawn.
Old 03-14-2021, 09:08 PM
jangodog
jangodog's Avatar
RVS, you really got the RC skills I know very little about these things.
jangodog is offline
11-14-2021 06:11 PM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
15
06-14-2016 09:52 PM
cver019
07-04-2015 06:04 AM
Quick Reply: Esc plug地play
Copyright ゥ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
Page generated in 0.10590 seconds with 12 queries
