Conscendo Evolution Spectrum Binding
Old 08-14-2021, 08:29 PM
MidwestGuy
Default Conscendo Evolution Spectrum Binding
Hello,
I have a Spectrum DX6 and a bunch of Horizon planes. I continue to be baffled, after years, at how they can exhibit different bind behavior, with some being trouble-free and others just not.
Here is my question. I setup my new Evolution today. I created a new Acro-type model in the DX6 per the instructions. I can bind no problem *if I first remove the receiver cover and press the bind button* - but not if not.
With most of my HH planes, I plug in the battery, turn on the TX, then bind.
Why is this one different? Am I doing something wrong?
A screw holds on the RX cover and removing it to bind is a PITA in the field.
Please enlighten me, and thanks in advance!
MidwestGuy is offline
Old 08-15-2021, 12:22 AM
Are you binding every time you fly? On mine, I bind once and then am done.I turn on the transmitter first then plug the plane in.
Old 08-15-2021, 03:28 AM
MidwestGuy
Even if you fly another plane with that TX? If I switch planes I have to rebind. I am almost positive controls do nothing until I bind again.
Old 08-15-2021, 12:07 PM
Midwestguy
Something is definitely wrong. All my receivers (various makes) stay bound to the appropriate model 'slot' in a DX6i in my case and have remained so for the life of the plane (years).
Once bound and everything is set up correctly its just a case of switch on the TX, select the appropriate model, connect the battery in the plane. ESC 'arms', control check and you are away, every time.
quorneng is online now
Old 08-15-2021, 12:25 PM
Yes, I can fly multiple planes on the transmitter and not bind between planes. As each plane is set up in the radio they keep the initial bind. Don't recall how many models the DX6 had in memory but there were several. New DX6 radios have 250 model memory.
When binding a new plane, sometimes I need to be a few feet away and they don't bind up close. But when flying several different planes, change the model in the transmitter then be sure the transmitter is on first then plug the plane in. https://spektrumrc.com/Products/Defa...ProdId=SPM6700 is a link to the newer DX6 manuals.
Old 08-15-2021, 04:54 PM
MidwestGuy
Originally Posted by quorneng View Post
Midwestguy
My TX is a gen 1, one of the earliest. Maybe time for a new one!
Old 08-15-2021, 07:00 PM
Shouldn't make any difference ...
You bind each model to a separate model slot on the TX .... so when you switch on TX - you choose which model you want and then power up that model.
It sounds like you are using only one model slot on your TX for all models ..... time for reading the Manual I think !!
Old 08-15-2021, 07:46 PM
MidwestGuy
That may be a good idea. The DX6 Gen 1 does have some reported weaknesses but even so it is not as old as my DX6i.
Old 08-16-2021, 02:04 AM
MidwestGuy
Nope - I have each plane setup under a different - Model.
There is really no other way to have per-plane settings.
Maybe there is some other reason the Evolution makes me rebind it every time I fly it.
Old 08-16-2021, 02:31 AM
Any chance of changing receives in it?
Old 08-25-2021, 03:50 PM
I would suspect there is a problem with the receiver. Check with Horizon Hobby.
As I understand the binding process, in simple terms, the transmitter provides an identification code to the receiver which stores it. The receiver looks for that code in the transmission and will ignore all others. If it loses the binding code it will have to be bound again.
Sounds like yours is not holding the binding code.
AEAJR is offline
Bald Paul
65
06-07-2017 11:42 AM
Dirky
27
09-05-2015 09:33 AM
woodmangler
05-22-2015 02:08 AM
abborgogna
04-15-2015 07:08 AM
Skyydogg
02-24-2011 03:33 AM
Quick Reply: Conscendo Evolution Spectrum Binding
Page generated in 0.09450 seconds with 11 queries
