Spectrum smart ESC Extension
Old 09-01-2021, 06:05 PM
johnsctt78
Default Spectrum smart ESC Extension
hi guys
im upgrading my e flite esc to a spektrum smart ESC. the issue im having is my battery side is about 8 inches short.could i add an extension to the smart ESC at that length and not have any issues?the EDF is the e flight thunderbird 70mm and the channel in front of the fan motor wont allow for it to go to far forward
johnsctt78 is offline
Old 09-01-2021, 07:27 PM
Past President of PSSF
No, you can't just add wire to the battery side. It does all kinds of bad things to the ESC. Ron Van Sommeren has several posts about this. Try to look up his posts.
You can extend the motor side, but that sounds like it may not work.
Can you cut a larger area?
Wildflyer is offline
Old 09-01-2021, 07:33 PM
johnsctt78
Thnx for the reply Wildflyer
im going to move the esc to the backside of the cockpit close to the CG and run a extension from the back of the ESC(motor side) to the EDF fan unit.this way no cutting etc and clean looking. thnx for the input
Old 09-03-2021, 07:18 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
If you cannot but extend, extend the motorwires, not the batterywires, and keep controller(s) close to battery(s).
No need for extra input capacitors, resulting in more space, less costs and less points of failure
Too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG
Contents
  • Two problems
    • Voltage spikes higher than battery voltage: transistor / powerFET / die breakdown.
    • Current through input capacitors too high: caps overheating/popping/exploding.
    • Nonsense Ron, I never had problems with long battery wires.
  • Example: four costly controllers consecutively cremated
  • Solution I: simply lengthen the motor wires instead
  • Solution II: add extra capacitors, rules of thumb
    Calculation spreadsheet
  • Capacitor type and polarity/orientation!
  • How & where (not) to add extra capacitors
    All capacitors as close to or on controller, do not distribute along batterywires.
  • DIY capacitor pack pictures
  • Capacitor & pack suppliers
  • Expert/manufacturer opinions & their rules of thumb
    They all say the same ... noise_reduction_101, switching_power_supply_design_101.
  • Cause, explanation, water hammer/knock analogy&
    , theory
    References
  • Measurements & scope traces
diy motor tips&tricksCumulus MFC •[/SIZE]
ron_van_sommeren is offline
11-14-2021 06:11 PM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
15
06-14-2016 09:52 PM
cver019
07-04-2015 06:04 AM
Quick Reply: Spectrum smart ESC Extension
Page generated in 0.07015 seconds with 9 queries
