EDF speed and throttle issue
Old 09-06-2021, 04:23 AM
Flying_Fast74
Default EDF speed and throttle issue
I have made foam board RC F-18 super hornet following Ben Harber's plans. I am using parts listed below. The issue I have is - After connecting the battery, when I increase the throttle on transmitter, the edfs speed up and reach to only about 80% max speed before max throttle position and then slow down to 30-40% of max speed when I shift to max throttle position. If I were to immidietly push the throttle to max speed instead of gradually, the EDFs will go to max speed, but stay at that speed only for a few seconds and then slow down to about 30-40% of max speed. In each subsequent tests with the battery still connected, the EDFs reach their highest speed about 10-20% slower than the time before. E.g. if I reconnect the battery and EDFs go to 80% max speed before slowing down to around 40%, then the next tests it will reach only upto 45% max speed, and then slow down to 30% of max speed, so on and so forth. Once the speed dips to or below that 30-40% mark, the speed remains constant irrespective of the throttle position. My battery is fully charged (though, I would welcome suggestion of a battery level tester). I want to make sure the edf speed gradually increases and reaches the highest at the full throttle position in repeated tests. I have used one ESC for each EDF. Both of my ESCs are connected to one battery, and are calibrated as well.
Connected parts list:
1) TWO Powerfun EDF 50mm 11 Blades Ducted Fan with RC Brushless Motor 4300KV (Balance Tested for EDF 4S RC Jet Airplane).
2) TWO ZTW Beatles Series 50A 60A Brushless ESC with BEC for RC Airplane 4S 6S (Beatles 60A ESC with Connector)
3) 3.5mm Banana Gold Bullet Connector Extension Cable for RC Brushless Motor ESC Extension Cable Wire (16AWG 30CM).
4) Flysky FS-i6 radio transmitter and FS-iA10B 4.0-6.5V/DC 2.4GHz 10 channel receiver.
5) OVONIC AIR 3000 50c mAh battery. 11.1V (Main Battery for ESCs)
6) ONE Blomiky 8.14Wh 7.4V 1100mAh 35C Li-ion-Po Battery with JST Plug (For External BEC)
7) BW RC Servo BEC UBEC 3A 5V Airplane Receiver Servo Power Supply
8) Onkuey T Plug Male to 2 T Plug Female Parallel Battery Connector Cable (120mm)
Flying_Fast74 is offline
Old 09-06-2021, 07:01 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Current is too high for battery and/or battery not fully charged?
Have you measured current?
How did you decide upon voltage, Kv and fan-type?
A batterytester is very crude, not really a good indicator for battery state of charge.
EDF calculator on
www.ecalc.ch
Without a watt/volt/current/multi-meter you are in the dark.
Until something starts to glow
ron_van_sommeren is offline
Old 09-06-2021, 07:05 AM
ron_van_sommeren
Do you have flying experience? With?
Brushless motors each must have their own brushless controller.
Don't use banana plugs, poor contact, high resistance, not designed for high current.
Connector tests, plus pictures
translate...www.elektromodellflug.de/hochstrom-st.-bu..html
Older version of that page, contains some other connectors
translate...www.elektromodellflug.de/oldpage/hochstromst/hochstromstecker.htm
Excellent site, do have a look at the controller, motor, charger, power supply, battery etc. tests.
Two connector soldering videos
www.youtube.com/c/Innov8tive8/videos
Connector soldering jig, keeps pins straight in housing while soldering.
wattflyer.com/forums/showthread.php?t=79119
Old 09-06-2021, 07:07 AM
ron_van_sommeren
UBEC is an old propriatery brand name, a generic informationless acronym for a standalone BEC: Universal BEC.
I prefer LBEC, linear, and SBEC, switching, because those two acronyms give very important info.
Don't forget to remove the red pin ...
... from one of your ESC connectors.
Otherwise you get two (slightly) different voltages: linear LBEC and battery, or LBEC and LBEC fighting each other.
Or in the case of switching sbecs, two frequencies fighting each other.
No need to remove the red pin if you are using a fake opto controller (just bec-less) controller,
Nor if you are using a true opto isolated controller, usually high power controllers.
There's also no need to remove linear LBEC red wire if manufacturer says so, but you must remove it when using switching SBECs.
But don´t cut the red wire, you may need it again in another plane.
Old 09-06-2021, 07:09 AM
ron_van_sommeren
If you cannot but extend, extend the motorwires, not the batterywires, and keep controller(s) close to battery(s).
No need for extra input capacitors, resulting in more space, less costs and less points of failure
Too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG
Contents
  • Two problems
    • Voltage spikes higher than battery voltage: transistor / powerFET / die breakdown.
    • Current through input capacitors too high: caps overheating/popping/exploding.
    • Nonsense Ron, I never had problems with long battery wires.
  • Example: four costly controllers consecutively cremated
  • Solution I: simply lengthen the motor wires instead
  • Solution II: add extra capacitors, rules of thumb
    Calculation spreadsheet
  • Capacitor type and polarity/orientation!
  • How & where (not) to add extra capacitors
    All capacitors as close to or on controller, do not distribute along batterywires.
  • DIY capacitor pack pictures
  • Capacitor & pack suppliers
  • Expert/manufacturer opinions & their rules of thumb
    They all say the same ... noise_reduction_101, switching_power_supply_design_101.
  • Cause, explanation, water hammer/knock analogy&
    , theory
    References
  • Measurements & scope traces
Old 09-06-2021, 10:29 AM
OK .. there's theory and there's practical ....
Linear BEC's will quite happily work together .. they don't care as the power supplied is a linear steady flow. I have many models with multiple Linear BEC's with red pins still connected. There is a possibility that having all connected - may give a failsafe factor if one BEC fails ..
Switch Mode BEC's as Ron says rely on pulsed / switched power supply and it is possible for one to affect the other causing one or both to 'malfunction' ..... strange thing is though - BY MISTAKE I have 3 models with SBEC multi set-ups and the red pins were left in ... with no ill effect at all ... each works perfectly.
Some people use a low loss diode or other divider to allow SBEC's to be used together - again possibly gaining a factor of failsafe if one fails.
Old 09-07-2021, 12:45 AM
Flying_Fast74
The symptoms you describe are certainly what you would expect from the EDF load exceeding what the battery can deliver.
The simple test would be to disconnect one EDF. If one EDF works normally then try the other EDF individually. It they both work individually then you can be pretty certain either the battery or possibly the wiring/connector is not up to the combined load. A 3000 mAh fully charged 50C battery and in good condition should easily be able to run one EDF at full power for 8 minutes.
Do you have another 3s battery? Even a modest 1800 mAh 20c 3s should be able to run one of those EDFs perfectly well.
Just remember it can save a lot of frustration, particularly with a multi, if you test everything individually on the bench before you add the components to the airframe.
quorneng is offline
thepiper92
General RC E-Heli Talk
30
07-20-2014 01:07 AM
thepiper92
24
06-12-2014 09:30 AM
Joe 1320
Electric Ducted Fan Jets
06-03-2013 03:53 PM
Joe 1320
26
08-17-2012 11:16 PM
Joe 1320
13
02-02-2012 02:15 PM
Quick Reply: EDF speed and throttle issue
Page generated in 0.08916 seconds with 11 queries
