3D Printing Post your electric plane related 3D ideas and plans.
LW-PLA and paint
Old 10-20-2021, 08:14 AM
Default LW-PLA and paint
I've been sprayiong PLA and LW-PLA with spray cans and usually no problems ... I keep can at distance to reduce the level of propellant that hits the item.
Yesterday I decided to use Acrylic Metallic Silver for a Vampire in LW-PLA ..... the PLA within minutes had softened and warped ........ overnight a few splits had appeared where layers separated and edges turned.
I have never seen this before.
I have used both normal spray Acrylic and Enamel without trouble. I can only assume a combo of the metallic and propellant caused this.
Old 01-04-2022, 04:18 PM
The foaming agent in LW-PLA makes for a thin skin which in turn means any degradation caused by the paint will be more significant.
In addition I think you will find 'metallic' finishes use more solvent in the mix to ensure the particles in the paint have time to 'settle' to give the required finish. The solvent is just as likely to attack a plastic as the propellent.
quorneng is offline
Page generated in 0.06958 seconds with 8 queries
