Different ESC's = Different output w/ same motor?
Old 01-25-2022, 08:13 PM
geb
geb
Default Different ESC's = Different output w/ same motor?
I had been successfully using an E Max 860Kv, 60 Amp motor with a Sky Power 80 Amp switchmode BEC purchased from the now gone Heads Up R/C.
While hurrying to straighten a bent connector pin, and NOT disconnecting the battery like I should have, I fried a component in the ESC.
So that ESC was replaced with a Hobby Wing Skywalker 80 Amp U-bec ESC, which ran the motor fine, except that it did not seem
to produce the same amount of power that the original did. In other words the throttle seemed to always have to be a little more
advanced to produce level flight at cruise speed as opposed to the original ESC using the same prop / batteries. I bought a programming card for the new ESC, and
changed timing which made no difference.
So, my questions is, if I bought a handful of 80 Amp ESC's for this motor, can I expect that each will deliver slightly different
power output to the same motor, given the same prop and battery ? Is there any way to determine which ESC will deliver the most performance for a given motor, short of bench testing each ?
Thanks for any thoughts on this subject that you may have.
Gary
geb is offline
Old 01-25-2022, 08:24 PM
I think there will be slight differences between brands and even same brands ...
But one aspect that often gets bypassed - is calibrating the ESC to Tx throttle. If the calibration is not done or not done correctly - you can experience similar to what you found.
Old 01-26-2022, 03:48 PM
geb
geb
Sol,....I think I did try recalibrating the ESC to the throttle, but never the less, come next spring, I'll recheck that.
Thanks for your suggestion.
Gary
geb is offline
11-14-2021 05:11 PM
11-02-2021 01:03 PM
05-28-2020 09:50 PM
terrynshed
06-29-2012 08:59 AM
RC Fan Chris
06-27-2012 07:10 PM
Quick Reply: Different ESC's = Different output w/ same motor?
Page generated in 0.08159 seconds with 9 queries
