Gws Warbirds Build Log
Old 07-15-2006, 12:09 AM
booger
Default Gws Warbirds Build Log
Well after recently completing a Gws Zero
http://www.wattflyer.com/forums/showthread.php?t=8385
I decided to do a build thread. I am by no means a master builder, just thought this might help some people tackling there first gws warbird build.
To show these birds can be built, to be everyday flyers, and be able to withstand being thrown in the vehicle and hauled around with you.(I do HVAC for a living so I drive a van most of the time. and throw my birds in back for a quick ride to the park.)
So first off this will be a Me-109 build, Mostly stock stuff except for power system,and batteries.I will be glassing this model as I glass most of my foam birds. For durability as noted above. This will also have a removable cowl for motor access.
First up then making the battery compartment large enough for a 3 cell Lipo. I use a propane torch and heat a wire to do most of my enlarging. and then I open the air channel. For the battery to get air around it. If you butt a battery all the way to the front it blocks the air channel. So I widen this more than the battery as seen in pic below.
Next, I cut the cowl off of both fuse halves at the bulkhead. Then I install the pushrod tubes in both halves of the fuse and secure with scotch tape. Then you guessed it glue the two fuse halves together. I used 5 min epoxy for this very sparingly. Being careful to line up end, and to get a nice straight fuselage from front to back
Feel free to chime in as you like for discussion
Rob
Name:	edited Me-109 build pics 001.jpg
ID:	14097   Click image for larger version
Name:	edited Me-109 build pics 002.jpg
ID:	14098   Click image for larger version
Name:	edited Me-109 build pics 004.jpg
ID:	14099   Click image for larger version
Name:	edited Me-109 build pics 005.jpg
ID:	14100   Click image for larger version
Name:	edited Me-109 build pics 006.jpg
Name:	edited Me-109 build pics 007.jpg
booger is offline
Old 07-15-2006, 12:18 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Good luck with the build and thanks for posting it. I've been looking around at Messerschmitts and there just aren't a lot to choose from in the park flyer size range. I've heard positive and negative about the GWS so it will be good to watch it progress.
Grasshopper is offline
Old 07-15-2006, 01:04 AM
booger
Next up is to fill panel lines with light weight spackle. I use DAP Fast n Final available at Wal-mart. I am not anal about this, but i just fill till just below the surface i do the smoothing out after the fiberglassing. then a light sanding till smooth by feel.
Then i cut 4 short dowels 1/8th stock 1 inch long. and cut one more about 5/8in. this is the one i use to mark the fuselage from the cowl. I mark the cowl for 4 dowels like pic below. then use a 1/8 drill bit to hand drill 1/2 deep holes at marks in cowl. then use 5/8th dowel to mark the fuselage for it's holes with the cowl.then drill holes in fuselage. Then use polyurethane glue for the one inch dowels in the cowl. Then i put vaseline in the holes in the fuselage to prevent glue from bonding two surfaces together. Separate the two with wax paper and line everything up and secure with tape and let sit overnight.
Name:	edited Me-109 build pics 008.jpg
ID:	14113   Click image for larger version
Name:	edited Me-109 build pics 009.jpg
ID:	14114   Click image for larger version
Name:	edited Me-109 build pics 015.jpg
ID:	14115   Click image for larger version
Name:	edited Me-109 build pics 010.jpg
ID:	14116   Click image for larger version
Name:	edited Me-109 build pics 011.jpg
booger is offline
Old 07-15-2006, 01:39 AM
booger
Next I cut 4, 1/2 in long peices of carbon tube that have a 6mm outside diameter and just over 1/8 inside diameter. I use a 6mm drill bit to enlargen holes in fuse for carbon. Fill the carbon with vaseline and put foam safe ca in holes in fuse an slightly recess carbon peices in fuse. let sit to dry.
Next I cut a piece of 3/32 basswood 1/2 wide by roughly 2 in long and another 1/4 wide by 2 long. Then use the hot wire to melt out the sections of foam around the elevator and rudder servo mount location. these will serve as hard points for the servos. (less slop equals better performance) as in pic below. and glue with polyurethane glue(for its gap filling qualities)
Next up I glue the wing spar in, I use fiberglass rod as this is what I have on hand. and I fill the landing gear mount hole with spackle and fill panel lines on wing with spackle sand smooth when dry (all my planes are usually belly landers as i have nice grass at my park to land on)club field is over 20 miles away.
Name:	edited Me-109 build pics 014.jpg
ID:	14125   Click image for larger version
Name:	edited Me-109 build pics 013.jpg
ID:	14126   Click image for larger version
Name:	edited Me-109 build pics 012.jpg
ID:	14127   Click image for larger version
Name:	edited Me-109 build pics 020.jpg
booger is offline
Old 07-15-2006, 05:27 PM
booger
well now for the glassing.
I usually cut strips like seen in pic below. It makes getting around funny shapes easier for me. All I basically do is dampen surface with the poly, lay on strip of fiberglass cloth, and dab more poly on the cloth till saturated though the material. then brush the remaining towards a point to get it off of the model.
Then I cut the ailerons from the wing and glassed the tips first. reason being makes the tips less likely to break from being handled while glassing the rest of the wing. But first I instal the aileron pushrods before glassing then glass the wing. and all remaining parts of the airframe. I leave a seam for the rudder and elevator to be cut at a later time.
Name:	edited Me-109 build pics 025.jpg
ID:	14159   Click image for larger version
Name:	edited Me-109 build pics 026.jpg
ID:	14160   Click image for larger version
Name:	edited Me-109 build pics 017.jpg
ID:	14161   Click image for larger version
Name:	edited Me-109 build pics 018.jpg
ID:	14162   Click image for larger version
Name:	edited Me-109 build pics 019.jpg
Name:	edited Me-109 build pics 024.jpg
ID:	14164   Click image for larger version
Name:	edited Me-109 build pics 028.jpg
booger is offline
Old 07-15-2006, 05:33 PM
booger
And here is a few pics during glassing and then all the pieces glassed.
Name:	edited Me-109 build pics 030.jpg
ID:	14166   Click image for larger version
Name:	edited Me-109 build pics 031.jpg
ID:	14167   Click image for larger version
Name:	edited Me-109 build pics 032.jpg
booger is offline
Old 07-16-2006, 04:33 AM
booger
Well today i had a pretty good day working on the Me-109. I hinged the ailerons with ca hinges and foam safe ca. And did all the sanding and painting.
I kinda went with a wild camo and gray. I use the krylon acrylics available at wally world. and used a matte finish clear acrylic sealer. this kind of paint dries really fast. So I got alot of work done on it today as it was 100 freaking degrees here today with high humidity.
Oh did you notice the zero in the background of the aileron pic?
Name:	edited Me-109 build pics 033.jpg
ID:	14177   Click image for larger version
Name:	edited Me-109 build pics 034.jpg
ID:	14178   Click image for larger version
Name:	edited Me-109 build pics 035.jpg
ID:	14179   Click image for larger version
Name:	edited Me-109 build pics 036.jpg
booger is offline
Old 08-27-2006, 03:29 AM
alienx
alienx's Avatar
Looks really good. I'll be watching. I have my first GWS build just started, so I'll be paying close attention.
How do you feel about the torque rod set-up? And do you know how much weight the glass and paint add?
Andy
alienx is offline
Old 04-06-2007, 09:22 AM
Balil
foam murderer :D
Balil's Avatar
lol i finally broke my 109 out the other day and slapped some paint on it... i really need to finish that build.... maybe one of these days
Balil is offline
Old 09-21-2007, 04:31 AM
rick88ss
No more posts here for awhile. Do you have any pics of the completed me109? What size battery fits?
rick88ss is offline
BigBird271
10-03-2016 08:47 PM
TVCasualty
Foamies
34
03-11-2009 04:39 AM
griffindor
08-10-2008 01:51 AM
fr4nk1yn
27
02-26-2008 12:47 AM
Tinman
Warbird Electrics
63
06-12-2007 07:34 PM
Quick Reply: Gws Warbirds Build Log
Page generated in 0.11321 seconds with 39 queries
